and remove the ECU harness connector from the ECU. Remove the bottom cover of your ECU. Use a #2 cross-tip screwdriver and unscrew all the screws that hold the Main board in by two or three threads. Then screw them back in real tight. You may have noticed that the screws closest to the harness connector were slightly loose at first.
